hi
jus got bit comet and any time i want to download an application, it sya this. “To display language character correctly you need to install the following language packs: chinese simplified”, and i don’t still get to download the app. someone please help. thanks.
I’m not sure which version you are using. Version .70 is the latest we are supporting at this time.
If you are having this issue while searching for torrents from within bit comet, then please use your internet browser to find the file.torrent. Then you can open it with bit comet.
Regards,
Thanks, i 'm currently using version .70 as well, and when i start up bit torrent it usually says the same thing. + how do i know where to find .torrent file with my internet browser? Thanks
Here are a couple good sites…
http://www.mininova.org/
http://thepiratebay.org/
these two do not require you to register and are pretty safe.
If you can find a time when they are taking new members, I highly recommend…
http://www.demonoid.com/
Or if you know someone to give you an invite. Demoniod also is far less likely to have viruses or bad torrents, so get an account if you can. Note: you will be expected to keep min 1.0 ratio.
Another Very safe site is…
http://torrentmatrix.com/
It is also a privite site but I believe enrollment is open.
This should get you started
Thanks a lot for the help suspect, it turns out demonoid had opened registrations, so i just registered. good looking out on the info. peace
