HELP!!
Please can anybody help, i’m useless with these sorts of things. Downloaded a Civ IV torrent, complete with what I thought was a No CD Crack, but I cant get it to work. I have two icons that would be used to start the game, when i click on one of them it says please insert the CD ROM. When I click the other it says “This application has failed to start because boost_pyhton-vc71-mt_32.dll was not found. Re-installing the application may fix this problem.” I have of course tried to re-install it but no joy. Can any computer whizzes out there help???!?!
The currymonster
This forum is for help with the BitComet client. Once you’ve downloaded the torrent, BitComet has done its job. Your question would be appropriate for the general computer help forum, so please make an effort to post questions in the correct forum.
Included with the download, possibly in a subdirectory, was an .nfo file or a similar small text file with informatin on how to install the game and the crack. Use Notepad to open that file, read and follow the instructions.
You really should have figured this out for yourself. Software piracy does assume that you have a good amount of initiative and curiosity. If you don’t, then buy the game and get the manual with it’s step-by-step guide.
http://forums.bitcomet.com/index.php?showtopic=3471
