I live in an apartment in which the ISP is provided by the apartment, anyway i use to be able to download torrents all the time, but noticed they must be blocking the program now, because it never downloads anymore. Is there any way to get around this? I do not use a router, and i’m connected directly using ethernet line, and not wirelessly.
Turn the encryption to always and the same goes for NAT Traversial. You are using BitComet 0.70 aren’t you?
Yea using .70 but i had nat and encryption set to auto detect hopefully the change will help.
