help
when i download music cant burn it??? it says my windows media player wont play it??? not supported??? or something???
Windows Media Play doesn’t come with codecs/filters. So it can only play a few types of audio. If you want to use WMP as your all purpose player (thats fine) then you should download either CCCP or FFDShow. This will install the decoders you need to play almost all audio/video files.
