how can i reset bitcomet options to default?
Firstly exit BitComet, then delete your bitcomet.xml, which can be found here:
Vista/Win7 : %SystemDrive% \Users\Username\AppData\Roaming\BitComet
XP : %SystemDrive% \Documents and Settings\Username\Application Data\BitComet
When you open your BitComet again, the options will be set as default.
thank you
