I have recently downloaded a number of movies and would like to add some comments to the Torrents.I have searched numerous guides, FAQ’s, forums etc without success. How is it done? Thanks
You first need to sign up here. Then go to the comments section of each torrent in BC and make sure you write the correct verification code.
Thanks Vasy, I followed the link to CometID, entered the req info and are now logged in. I can find no reference to a verification code.I have been back to my Bitcomet download screen, selected a completed download, highlighted the comment link but can still not enter any text.
/monthly_01_2011/post-53701-12953633760846.png" rel=“”>
Now, you post screenshots of the comments tab, after scrolling all the way to the bottom.
You also need to log in in the BC interface. /monthly_01_2011/post-53701-12953636568049.png" rel=“”>
Thanks Vasy,
After seeing the screenshot on your latest reply I realise that Bitcomet version 1.07, that I have, does not have that window. I have now upgraded to version 1.25 and have now successfully posted my first comment.
Problem solved.
I have bitcomet v1.20 installed in windows 7 but the programme keeps coming up with programme not responding, is there anything one can do to sort out this problem ?
ericross, probably, but first, it’s confusing and a bit ill-mannered to jump into the middle of someone else’s thread to try to hijack it for your own issues. Start your own thread. Second, you didn’t provide anything like enough information to help you. Most of it should be obvious, but just in case, there’s a sticky topic titled, “READ BEFORE POSTING” that you should read, before posting your question, in its own new thread.
