my siblings are always terminating bitcomet when i am downloading even if I activated the boss key
they search bitcomet then they terminate it… can anyone help me…
What operating system?
Setup a password for your windows user account, make them a limited account and then lock your session with WindowsKey+L.
This won’t stop them from shutting down the computer.
You can try pressing Alt + `…
The second button to press after holding the Alt key is the one to the left of the numerical 1 above your Q button…
Press once to hide and the second time to unhide…
It will disappear from your taskbar and will not even show up on the row of small icons on your bottom right hand side of the screen…
I have tested this on both Windows XP Professional and Windows Vista Home Premium…
This should work the same on other OS as well…
I accidentally discovered this feature while trying to press Alt-Tab…
That is the default boss key, tolonglar.
