How do I seed a torrent I created?
I have download bits and pieces of a large animated series and organized it so that it’s alot better than some of the other torrents of this type but I can’t seem to get people to connect so that I can share it. It says that there are between 10 and 26 peers that are looking for the file but can’t connect.
How do I correctly set up my own torrent so that others can access it?
I’ll attach the torrent I created…
Whether you did something **incorrectly **or not we cannot tell, as you didn’t say anything about what you did so far.
Did you make sure you have an open listen port? There could be a whole host of other problems, but this specifically would create the issue you’re describing.
