when I click preview or play in bitcomet, it goes to windows media player, is there a way I can change it to VLC player?
thank you
thank you
Options → Advanced
Key: ui.preview_program_path
First right click on the file you want VLC media player to read and choose “open with.” Then choose from a list of programs that can be used to open the file such as VLC media player. Then check the box near the bottom that says "Always use this program to open this type of file
This will change the Windows default player for that filetype. It will not change the BitComet player at all. To change the player that BitComet uses, requires that you change BitComet’s settings, not Windows’.
I am still confused here. To change the default Bitcomet player options>advanced
and what about the “Key”? Just enter the path to the new player??
if you installed VLCplayer to its default installer specified directory then on BitComet just go to Tools–>Options–>Advanced and in the “ui.preview_program_path” (@ the lowest) type in the directory path of your VLCplayer OR copy and paste this → C:\Program Files\VideoLAN\VLC\vlc.exe
