how to change subtitles color
Hi,
is there any way to change subtitles color from white to yellow?
Finally!!
After years of googleing, reading this forum, etc, I had already given up and turned off the subtitles in the MPCStar, and installed ffdshow to put subtitles in yellow when I read the post about arabic subtitles and I figured out how change the color of the subtitles.
If u press ctrl-i, to see the file properties info, u can change the directvobsub settings and change the color there.
why this is not in the options or subtitles panel? was very difficult to find the place where you guys put these settings and did not find any help talking about where to modify.
That would be because DirectVobSub is not a part of MPCStar. There are many filters out there. You can choose to use any of them, but you are responsible for configuring the ones you decide to use. There are no plans to provide configuration instructions for all of the possible filters, or to provide interfaces for them – most don’t even allow that. You must use the filter’s own interface to configure it.
