HOW TO INCREASE DOWNLOAD SPEED
:huh: HEY PAL I USE BITCOMET TO DOWNLOAD TORRENTS… I HAVE 128 KB/S INTERNET CONNECTION… THE CONNECTION SHOULD GIVE AROUND 20KB/S DOWNLOADING SPEED…BUT MY TORRENT DOWNLOADER DONLOADS FILE AT 8KB/S… IS THERE ANY THING I CAN DO TO INCREASE MY DOWNLOADING SPEED…
:frowning: HEY PAL IS IT TRUE THAT IF U OPT FOR PRIVATE TRACKERS…U COULD DOWNLOAD TORRENT AT A FASTER RATE THAN PUBLIC TRACKERS?
First of all, do NOT reply to your own message, us the edit function.
Second, it is considered rude to type in ALL CAPS
now, concerning your internet connection. Your ISP provides 128kb/s, which is equal to 16kB/s, not 20kB/s
Since your upload speed is likely much less, you arn’t likely to reach this speed.
Considering this, I think your download rate of 8kB/s is quite good. You may see speeds of 12kB/s on very well seeded torrents, but not on most.
As for private trackers, some are better seeded, but not all.
Some public trackers also are well seeded.
ps. If you havn’t done so already, I suggest you review our settings guides.
And turn off that caps lock because that will get you in trouble since you have posted in all caps several times.
thank’s… my averege 5kb/s - 7 kb/s :angry:
