How to transfer............?
How do i transfer partially downloaded file from from utorrent to bitcomet???
I have manual hash checked,but still start with 0%.
PLEASE HELP!
TQ
Locate the file in your BC default download directory and look at it. BitComet will optionally append the extension, “.bc!” to unfinished downloads, and you need to determine whether this has been done. If it has, merely edit the filename to remove the extra extension. Load the torrent into µtorrent, making sure the download directory is pointing to your partial file. Do a manual hash check on the contents. When it finishes, µtorrent should be ready to resume downloading where BitComet left off.
