I have an Explanation Point!
Any idea on why I have these errors on XP Pro SP2 system?
Default tracker optimization rules file loaded.
IP rules file: ipfilter.dat loaded, 0 entries.
Start Listening at TCP Port:14624
Start Listening at UDP Port:14624
BitComet 0.70 is running on:
CPU : Intel® Pentium® 4 CPU 2.40GHz 2392 MHz
RAM size : 1.49 GB
OS Version: Microsoft Windows XP Professional Service Pack 2 (Build 2600)
Windows XP WF Status: TCP Port is opened in Windows Firewall.
Windows XP WF Status: UDP Port is opened in Windows Firewall.
Update Local IP: 72.135.10.212
Windows XP ICS Status: cannot find working ICS.
Windows XP UPnP Status: device not found!
Those aren’t errors. There settings you don’t have/need. You can turn off UPnP as thats for routers that support UPnP. ICS is for Internet connection shareing. Unless you use Windows Firewall (ICF, they share a setting) you can turn that off as well.
And from the looks of your settings you can turn the IPfiler.dat filter of as well since you don’t have a list loaded. Is easier/better to run Peer Guardian for that anyway.
