i’m using BC0.70 and i face some severe problems these days.
the first is that i’ve got lots of seeds but the speed is still slow!Here is the pic
and another problem
When i was in China, almost everyone told me to turn on the UPnP of the router.And i did that. But when i saw the bbs here, everyone says u should turn off the UPnP.It confused me…
the third, i’ve got a problem with the description from BC below:
Default tracker optimization rules file loaded.
Start Listening at TCP Port:50000
Start Listening at UDP Port:50000
BitComet 0.70 is running on:
CPU : Genuine Intel® CPU T2050 @ 1.60GHz 1596 MHz
RAM size : 511.35 MB
OS Version: Microsoft Windows XP Professional Service Pack 2 (Build 2600)
Windows XP WF Status: TCP Port is opened in Windows Firewall.
Windows XP WF Status: UDP Port is opened in Windows Firewall.
Update Local IP: 192.168.1.100
Windows XP ICS Status: cannot find working ICS.
Windows XP UPnP Status: Found WANConnectionDevice [Microsoft] [http://www.microsoft.com/]
Windows XP UPnP Status: Found Service: WANIPConnection
Windows XP UPnP Status: WAN IP:
Windows XP UPnP Status: Error occur when Adding TCP Port Mapping!
Windows XP UPnP Status: Error occur when Adding UDP Port Mapping!
Windows XP UPnP Status: Found WANConnectionDevice1 [Linksys] [http://www.linksys.com/]
Windows XP UPnP Status: Found Service: urn:schemas-upnp-org:service:WANEthernetLinkConfig:1
UDP tracker report: WAN IP = XX.XX.27.106
what does "Windows XP UPnP Status: Error occur when Adding TCP Port Mapping!
Windows XP UPnP Status: Error occur when Adding UDP Port Mapping!"? does it mean that there is something wrong with my settings?
the fourth, i heard that i should turn off the UPnP and make the port forward. whats the difference?
My router is Linksys WRT54G.
Please help me speed up my BC
/post-11497-1160772883.gif" rel=“”>
