I,ve been using azureus and bitcomet for quite some time, but since a week my download speed on azureus can,t get higher then 10 kb/s and on bitcomet not higher then 35kb/s. in the lower right corner in says: DHT not connected.
I,ve tried the bitcomet beta version, and the DHT is connected but it says DHT connected node:0
what does that mean? and on the beta version its also not going higher then 40 kb/s
It sounds very much like your firewall settings have changed or a new firewall added, and as a result, your listening port is being blocked. Being blocked for TCP accounts for the slowdown, and being blocked for UDP accounts for the DHT issue.
