Dear all
I am now using Windows XP X64 eidition, I would like to ask which version of BitComet should I download to use? I tried 0.70 and 0.72, both of them cracked in the middle of the progress.
I am now using NOD32 anti-virus program, does it has any conflict with the program?
Thanks for your advice!
Best Regards,
Kin
Our latest stable release is version .70.
I’m not aware of any conflicts with winxp 64.
Please discribe how it crashes, and what if any error messages you get.
The errors are listed as below.
Errorlog.txt crash log
Crash.Dmp
I would first suggest you download and try a previous version. I am told that .64 is stable.
If you are unable to download, let me know and I will find a way to send it to you.
Note, I will try, thanks!
With 0.64 version, it works fine. Thank you very much for your help!
