If I''m using 2 USB Wireless Network Adapters; re my Listen Port
I just want to double check on something I think I read on a page in BitComet somewhere, a few weeks ago.
It said that if I’m using USB Wireless Adapters to get my signal, I will never be able to get my Listen Port to open.
Can anyone answer this for me?
Thank you!
There is no problem using usb adapters, it depends on the type of connection. If you’re using a wwan or celular type of internet connection, then you will usually be blocked. If it’s a wifi adapter that connects to a router you control, then it shouldn’t be a problem.
