EDIT: PLEASE IGNORE TOPIC - I FIGURED IT OUT 2 MINUTES LATER BUT DON’T SEE OPTION TO DELETE POST!
What version of BitComet are you using? - BitComet 1.29
What type of Internet connection do you have (ADSL, etc.)? - UVerse (VDSL)
Do you have a modem? Do you use a router? What make and model are each one of them? Have you forwarded your port?
I have a residential gateway (2Wire 3801HGV)
I have a wireless connection to several devices, however my SonyVAIO PC is connected via cable to a NetGear 8-Port Gigabit Switch which is connected to the wall
What version of Windows, Firewall and Antivirus do you use?
Windows XP - Media Center Edition SP3
Windows Firewall
No Anti-Virus Protection (shame on me … I know)
I followed the port-forwarding instructions to no avail … The IP which is blocked is my “Broadband” IP address (99.3.1XX.XXX) and not the IP address that comes up when I execute ipconfig/all … When I pull up my 2Wire settings page, the blocked IP address is the one listed under “Broadband”, and not the other one which is listed under “LAN”
Can someone please point me in the right direction? Thank You
