The button for the colors doesn’t work. No affect when clicking it.
So I need to add my colors manually:
[./color=red] [./color]
[./color=blue] [./color]
[./color=orange] [./color]
What is my problem? Why the color tag doesn’t work?
I am clicking here:
/post-2029-1152894371.jpg" rel=“”>
The color manu is opening near the top left corner of the web page:
/post-2029-1152894391.jpg" rel=“”>
Hi there, I’ve PMed you with a set of steps which hopefully may assist you.
another screenshot
/post-2029-1159545250.jpg" rel=“”>
Hm, this should mainly be an issue with your browser, rather than our forum, since I’ve tried accessing the pallete colour with my 4 different PCs at home, though amusingly, one of my PCs allowed the colour pallate to appear much further up, just like yours in the screenshot.
Hi,
I’m having the exact same problem.
I’ve got BC .70, Win Xp Prof SP2, no router and use (don’t get too upset …
) IE (until I figure out how to give Firefox a try).
What does the browser have to do with this odd occurrence?
At work, while nobody was looking, I tried using it (Text Colour) but got the same results—> all the writing was in black and the colour palette was ‘wayyy over there’.
Regards,
cassie ![]()
Hi,
Regards,
cassie ![]()
I’m trying to see if the color will work for me now
EDIT: as you can see it works correctly. Here is how it works. Press the text color button
this will appear in your message when you pic your color (red in this example)
[color=#FF6600]
Then enter your message, and again press the text color button and this will appear
[/color]
Which closes your color tags.
Thanks a lot!!
Now, I know how it works… finally!!
Regards,
cassie ![]()
