hello forum moderators
It’s been a while… how are you guys ?
anyway after very long time bitcomet driving me crazy now
OS : windows 7 ultimate (x64)
BitComet_1.36_(x64) & (x32)
RAM : 2 sticks 4GB each single Chanel mode
Issue:
this strange problem started last night when I started downloading this
magnet:?xt=urn:btih:9E515E501C3A80EA29A406ADBD505149AE3E4E92&dn=mass+effect+galaxy+edition+updated+repack+by+rg+mechanics&tr=udp%3A%2F%2Ftracker.publicbt.com%3A80%2Fannounce&tr=udp%3A%2F%2Fopen.demonii.com%3A1337
1.when I ran this torrent on my BitComet_1.36_(x64) it ran beautifully with my max speed for about 20 minutes after that it crashed, showing the crash window asking permission for reporting
2.second time same thing happened when I was watching a video but instead of crash window there was this other window which asked that the bitcomet isn’t responding and should I exit it or not I clicked on OK but bitcomet never exited ! (I could see it in notification area but r-click and double click didn’t worked ) stranger than that I was only able to access the currently running applications(.exe) like VLC, my antivirus I couldn’t run any new program ! I tried opening task manger by booth manual and shortcut key method but it didn’t show up! then I tried shutting PC down, but every time I clicked on shutdown nothing happened! ( probably becuse i cheked that option which avoids shutting down of PC when running bitcomet) ultimately I was forced to power-down
3.this time I used the zipped version of 32 bit BitComet_1.36 and kept the task manager open and after 3 hours same thing happened just like the second time,but this time around I had my task manger open so I tried to exit the task from there but nothing happened, tried to open a bunch of application, I could see them in my task manger running but nothing showed up, again I was forced to power-down
4.just like the 3rd time but the problem started when hash checking stuck at 7 % and tried to stop it, then tried exit it then disk busy Icon came up, then it vanished from notification area but I could see it in the task manger ultimately forced to power down ![]()
tried in some other clients no problems found
