Hello,
Why the h*** isn't there an option to select a path where to instal Bitcomet?!?
You take time to add all that junk but not the basic function where to instal it
Hello,
Like every installable app - it HAS to be installed on the ‘C’ drive. The only ones that don’t install there are ‘portable’ apps that have their required .dll files, etc in a self-contained folder.
Some apps will let you mount a part on other drives, but the main parts will go to Program Files (or the x86 segment). That's why the folder is called 'PROGRAM FILES' - that's where programs go
