Installed BitComet 64-bit but 32-bit not uninstalled
I have a 64-bit computer running Windows 8.1 64-bit.
I have installed BitComet 64-bit but 32-bit was not uninstalled & the old directory is still there.
Windows ‘Programs & Features’ and ‘Revo Uninstaller’ both now have no ‘history’ of Bitcomet 32-bit install.
Is there any problem deleting the Bitcomet 32-bit directory(folder) ?
AND/OR are there any files I should keep/copy and place into the 64-bit directory(folder) ?
Any other potential problems or actions I should be aware of ?
Thanks,
Rod
you should be able to delete it if it bothers you, or you can first rename the folder and make sure everything works properly, then delete.
