hi there
when i first starting using bitcomet 0.70 i was getting between 250-300kbs downloads,now for some reason i cant get above 90kbs if im lucky .
what have i done wrong please help me re-confiqure so i can get fast downloads again :unsure:
hi there
I suggest you review our settings and speed guides.
keep in mind that you can only receive data as fast as the peers send it to you.
The most common cause of slow speed is users that run multiple torrents.
I suggest you try downloading “open office”. If you system is configured properly, you should get good speed.
