Internet connection problems
I just updated to version 0.70 from 0.6. When I updated, the new version kept all of my existing and incomplete torrents, but it is no longer able to locate my internet connection. I can add new torrent files, but none of my current or new torrents will connect or begin to download; they all just show the >> icon.
How do I get BitCommet to recognize my connection again?
This sounds like a firewall problem.
Please delete your exsisting rule for bit comet, and make a new one. Although some firewalls will detect the change and ask you if you want to allow, others will not.
Thanks, that seems to have fixed the problem.
