i need to start building an intranet and i really need assistance in terms of what software to use, requirements, what i need to know and all
please help
please help
not too sure what this has to do with torrents
try here http://en.wikipedia.org/wiki/Intranet
i suggest a linux box server to start, keeps the cost down
If you mean a home network then just get yourself a good router and link the computers into it. Yes I know that sounds way to easy and extreamly simplified.
Look at what you have as in how many computers and what OS they’re running and weather their network cards are 10/100 or 10/100/1000. Do they support full deplex mode?
Then look at what you need speed wise. Do you plan to transfer video files or mp2 files over this network? Is it going to be used for gameing?
I can help you out and keep the cost down depending on what you want and the security you’ll need.
