Ipod Format
I downloaded a movie and it’s in the bitcomet format with the orange circle in the top left. How do I put that file onto my ipod? I tried using Cinema Forge but I think it needs to be a different .file thing.
Thanks.
… it’s in the bitcomet format with the orange circle in the top left.
What exactly do you mean by that?
There is no such thing as BitComet video format. BitComet is a BitTorrent client used to share files not a video encoder/player.
The only instance I can think of, when you will have an orange icon on the file is when your file still has the .bc! extension, a.k.a. it’s part of an **unfinished **download.
Every movie that you want to be used on your ipod has to be in .mp4 format. The easiest way to do this would be to download a video converter program preferable imtoo mpg converter
download the program ‘Format Factory’ you can change any video file to what you want. It’s a free download just do a google search. I use it all the time and it works great. you can also rip most dvd’s down to ipod format.
