To continue a download with another client, like BitTorrent or BitLord, cause I’ve been stuck with a torrent at 99.5% for about two days now.
Yes, it’s possible. Add the torrent you’re downloading from to the other client and direct it to download where you’ve previously downloaded. The new client should do a “hash ckeck” and see how much is downloaded and what’s left and then should begin to download again.
However, I don’t think it will help. If you’re stuck, then try a manual hash check with bitcomet. Then, there should preferbly be at least one seed for the torrent or some peers. In short, there might be no one that have the part of the file(s) you’re trying to download. Be patient.
I’ve been patient for 2 days.
I am conncted to 6 seeders, and I’m downloading at 0Kbs and uploading at 0kbs. How do you explain this?
Can’t say for sure. Do a hash check and wait, or try another client and see if it solves your problem. But honestly, I think that it will not.
You could try to add another trackers. It sometimes helps. Maybe they give you some extra peers, which have the pieces you need.
Here’s the topic about it
Can’t you just copy the tracker URL and paste it in the tracker list?
