Is There Any Parameter Features???
Hello Everybody!
I would like to ask you if I can start the bitcomet with some parameters.
Is there a way to start bitcomet in “minimized to tray” mode.
Also can I start it without its GUI, only the process (like pressing the ‘Boss Key’)
I am using BitComet version 0.70 under WinXP SP2 Professional
Thanks a lot. B)
Why don’t you spend some time familiarizing yourself with the options contained in the preferences? Look there before you ask a question about how to do something, just in case it’s right there in front of you.
(Moved discussion to the BitComet client help forum)
Thank you, and sorry for asking again, but I would also want to know if I can start only the proccess.
From the preferences menu i found only the “minimize to tray on start-up”
The boss key merely hides the icon. Most windows programs like BitComet require the GUI, so the best you can do is minimize it and hide the icon. Currently there’s no way to do that automatically, sorry.
