iso,bin and cue files
How can iso,bin and cue files be opened?Because some of the big files such as windows,games extensions are those type.
moved to general questions
Iso and .bin/.cue are types of disc images, and are meant to be burned to either a cdr, or dvdr disc (depending on the type of image.
You can also “Mount” these disc images in a virtual cdrom drive with a program like “alcohol 120%” or “daemon tools”.
Alcohol will also burn these types of disc images, as will most disc burning software.
to play it, a good program is the VLC media player which u can download at videolan.org
