I have search every where on internet, but i have no solution…
Searching from every forum to forum still no help about it. Download speed decrease from 40Kbps++ to >2Kbps. This is the worst speed i get for this 3 weeks. Waiting for the solution but none, dowloading from http and web-browsing is not a problem, only in Bittorent. I try a lot of bittorent client, no help. But i will only stick with Bitcomet, since i use it from 0.63 onward till now. Turning the encryption do help boost up a bit to 3kbps…but this is way too slow for 1Mbps Broadband.
You should really upgrade to 0.70. Anyway use a proxy for tracker communication and set Encryption to always.
Thanks for the reply, i try the 0.70, but no help either. I set it to encryption as always too. But the speed of downloading still the same slow. i guess nothing we can do if ISP blocked bitcomet? I thought as tech thing we should come out another thing that can by pass…will we? By the way, i read about you posting something call canyouseeme.org, i try that and it return result as fail, what should this trying to say then.
