it consumes many resources
Hi :smiley:
Why is that?
Is too much. :o How correct this? :frowning:
Thanks B)
BitComet can and will use up to 50megs of memory because of itโ€™s cache settings. If you want it to use less then go into the memory and lower it to 20 max megs of memory. Or you could buy more memory.
does it matter much if you allow bitcomet to use more or less memory?
i mean, for the sake of faster downloading
I noticed you are running a lot of torrents there (five I think).
If you look at your upload speed, you are uploading almost nothing.
People that run alot of torrents at the same time often end up connecting to peers and providing little or no upload.
This is the BIGGEST problem facing bit torrent.
If all users would limit to one or two (at most) torrents, we could all download much faster.
Your trackers and peers are gonna see you are not uploading and restrict or ban your connection.
Unless you have more then 1meg upload bandwidth, you really should not run more then one, and most of us have much less then one meg upload.
I have 8megs download, but less then 1meg upload, and would NEVER run more then two at the same time.
ps. concerning memory usage, I stopped using azureus when it began using over 100megs of ram. :o
Hi :smiley:
Sorry me english, is Google. :rolleyes: Where encounter that branch? I really like buy more memory but i live in 3 world here is really espensive.
Thank yuo for answer i have 256 k and mi configuation is 32 download and 8 upload I think that configuration for my connection is OK.
Thank for yuor help. B)
