Ive downloaded...now what?
Hi
Just downloaded my first full file. A PC game.
I know where all the files are stored etc and now want to know how i get the game to run. Do i have to write to a disk before it will work or is there some other way?
I know im probably missing something obvious here.
Help would be appreciated
no it is not nessesary to write the game to a CD but you need to tell us what type are the files you’ve downloaded:
*.rar
*.iso
*.nrg
*.bin
*.??? :slight_smile:
*.rar
*.iso
*.nrg
*.bin
They are .mdf and .mds
Will something like Isobuster do the trick and what do i need to copy to CD to run the game? I have installed the game succesfully but it keeps asking me for the CD as it would with the original
The best program you can use for image files like these (most games and big programs comes in such image conversion) is Deamon Tools.
But if you have already installed it all you need now is to search for no-cd crack for the game.
Check here.
Remember to use the .mds file for mounting or burning the disc image. The .mds files is the instruction file for burning & mounting programs.
Just download magiciso to burn mds/mdf to cd. It does a good work.
http://www.magiciso.com/download.htm
Alcohol 120% is also a good choice for mounting and burning these disc images.
