I’m using Windows 7 x64 Turkish and BitComet 1.25
My English is not very good, so i’m going to write an example step to step.
-First bug in “Batch Download”
Rigt click
Click “Download all links with BitComet” (I’m able to use this command over Chrome with DM-Bridge extension)
BitComet’s “Batch Download” window should appear…
To select certain files, Filter Image (or select certain files directly)
Download them to your default “Save Path” now.
They should be downloaded at your default “Save Path”
Execute steps 1 to 5 again. (select same files in step 5)
Now, Enter a new “Save Path”. For example type “c:\test” in “Save Path”
Click “Download Now”.
A window should appear: “Task exists. Current task progress: 100%”
Click “Re-download” (“Download” button should be inactive)
Click “Re-download” for others…
Open C: when the downloads complete.
Search for folder you’ve written to BitComet: c:\test
Oh no, there is a problem: Folder doesn’t exists.
Because BitComet downloads them to their old “Save Path”.
I think, this can be described as a bug. Because it should download them to the new “Save Path”, too.
At least, it’s a big problem for me to download common lessons’ pdf documents to separate classes’ folders.
-Second bug: Language selection except English and Main Window’s behaviors
Select “English” in the Tools>Language menu.
In the left panel of the Main Window, there should be “All Downloads”, “Torrent History”, “Torrent Exchange”, “Torrent Sites”, “Free Online Games” under Channels.
In the right side of the up panel, there should be a search bar allowing selection for some sites (ThePirateBay, TorrentRoom, …)
Now, select “Turkish” in the Tools>Language>Others menu. (Why “others” by the way?)
In the left panel of the Main Window, “Torrent Sites” and “Free Online Games” under Channels should be disappeared.
In the right side of the up panel, selection for some sites should be not-working.
I think, there’s a bug here.
Thank you for reading…
