kerio firewall
i just downloaded a torrent for kerio and the installation went fine, auto restarted kerio and then tried to get back into bitcomet and couldn’t find server. no problem, just disable kerio as windows firewall is still operational. anyways to make a long story short, when i try to connect to kerio firewall at local host i get the screen that i have attached. the torrent came with a keygen, but i am not sure how to apply keygens, never downloaded any thing that needed it before. juust need a little advice here if someone could be so kind. thanks!
p.s. i am running avg free edition, avast, and trojan remover for virus protection
Why dont you just use the free version of Kerio, it works well enough. There is no need for you to have a hacked version of Kerio’s enterprise software meant for corporations and not for home use.
I would say that since you didnt install the hacked one correctly in the first place that it is unlikely that you will get it to work. You should try to uninstall it completely and then get this version of Kerio which is free.
okay i’ll do that. i should leave windows firewall on until i get kerio installed?
Yeah, just leave windows on until you get the other version installed. You should never log onto then net without a firewall. Especially if you’re using p2p software.
