ok so. when there are open several windows with 2+ tabs in each if you close one it will ask you just to close all tabs and wont ask you to save them or not. thats normal this should be so. but when you have window with 2+ tabs and download manager open, download manager is counted as another window and unless you close DM you wont be able to save your tabs. I think that should be corrected, this brings lot of misunderstandings and who dont know computer well may do something wrong and make everything worse.
DM should close with last window or should’t be counted as window.
