I need a seed to finish if someone will help? At 98% :huh:
Thanks
Thanks
I realize you must be new at this, but do you assume there is only one torrent for this movie on the internet?
There could be hundreds, and only one of which could be yours, so there is no way anyone could help you if you don’t post the proper information.
Thanks
Ok what info is needed?
I guess there are alot of recodes out there for this. It does look look like
someone put in a seed since I am at 1k for now, yippie!
The polite way to request a reseed is to list the full name of the torrent, as well as the tracker, and a link to where you downloaded it torrent.
The best place to request the reseed would be on the trackers web site.
Is there a copy and paste section? Under properties maybe? Using polite voice
Go to the web page where you downloaded the torrent, then copy the “url” web address from your browser by highlighting the address, then “right click” and select “copy” from the menu.
Then “right click” here in your reply and select “paste”. it will then make a “clickable” link like this…
http://forums.bitcomet.com/index.php?showtopic=3673&hl=
If your browser doesn’t support the “copy/paste” menu from “right click” of mouse, then you can highlight and use the following keyboard buttons.
Copy= control and “C”
Paste= control and “V”
It still has not completed at 98%, is there a way to cut it off? Might just be credits seeing as it’s only 2%
