When I perform a search reguest the new window is in chinese instead of swedish that I have under language options!!!
That’s not easy
That’s not easy
This problem only occurs when you get an Internet explorer error page.
If you load a valid web page it will work fine, but “page cannot be displayed” error is in chinese.
When you get this, you will know that you have entered an address that is not valid, is offline, or your connection is not currently availble.
The problem will be corrected in future releases.
If you have any other problems with this version, you might want to install our latest “stable” release, version .70
You can also try working around this by deleting the Chinese language file from BitComet’s language folder.
