It is not possible for me to find a working listen poort.
Well, as H. Ford said: “Whether you think you can or whether you think you can’t, you’re right.”
if a room has 60,000 doors, yet you cannot leave… then perhaps you should stop looking for door 60,001 and simply open one of the previous doors (ports) and be on your way.
