Hi, I would like to ask you why when I installed the 1.24 version of bitcomet my listen port was immediately blocked?I use rooter and in the 1.21 version (which I used before that) there was no problem with the port.Once I installed the last version the problem appeared.I checked the NAT settings of my rooter but everything is OK there.I even changed the port but NO result.My firewall settings are Ok , too.Please help me!
P.S.
I installed the old version (1.21) and the port is open.But with 1.24 is blocked!?
Those dang rooters! They’re either digging up your cables while looking for food, or cheering so loud you can’t hear yourself think! No wonder there’s a problem with your listen port!
