listen port blocked
Buna baieti!
Probabil ati obosit sa raspundeti la aceeasi intrebare dar sincera sa fiu fara voi imi prind urechile: nu pot debloca portul de ascultare.
Sunt posesoare de Windows 7, modem de la orange HUAWEI E1752, Kaspersky 2011.
Multumesc frumos!
Hi guys!
You’re probably tired of answering the same question over and over again, but to be honest, I’ll go mental without your help: I can’t unblock my listen port.
I have Windows 7, a HUAWEI E1752 modem from Orange, Kaspersky 2011.
Bună! Eu nu am obosit încă. :slight_smile:
Problema la tine este Orange, toate porturile sunt blocate de la ei, și asta e valabil pentru toate conexiunile la internet printr-un modem wireless usb de la toate companiile de internet. (ZAPP, Vodafone, etc).
Hi! I’m not tired yet. :slight_smile:
Your problem is Orange, all ports are blocked by them, and it’s the same with any other internet connection via a wireless usb modem from all ISPs(ZAPP, Vodafone, etc.).
Si de aici sa inteleg ca nu am nici o sansa?
:unsure:
And by that you mean I have no chance in solving my problem?
Realistic vorbind, da. Dar poți oricând să-ți fertilizezi cultura de peri albi sunând la Orange cu problema asta…
Realistically speaking, yes. But you can always hasten your white hair growth by calling Orange support about this problem…
If your connection uses a cellular modem, then your only hope is to ask the provider for a dedicated port to use. I’ve never heard of one actually doing that though.
One other thing you can try is getting BitComet version 1.02 and enable “Nat Traversal”. It uses “udp hole punching” to achieve remote peer connections. This feature was removed in version 1.03 to “improve tcp connection efficiency”, so 1.02 is the most recent version to support this technology.
note to vasy: have fun translating “udp holepunching” lol sorry
Daca conexiunea ta folosește un modem celular, atunci singura ta speranță ar fi să ceri distribuitorului un port dedicat pentru asta. Deși nu am mai auzit de unul care chiar ar face asta.
O altă idee ar fi să încerci versiunea mai veche 1.02 de BitComet și să activezi funcția „Traversarea NAT". Aceasta folosește tehnica de „găurire prin udp" pentru a obține conexiuni de la alți parteneri. Această funcție a fost scoasă in versiunea 1.03 pentru „a îmbunătăți eficiența conexiunilor TCP, așa că 1.02 e cea mai recentă versiune care folosește această tehnologie.
That can’t have a perverted sense, right? She can’t just take the wrong meaning out of it and start flaming everything in her way, right? .. RIGHT?!
Oh well…
Ok baieti:))) ideea cu fertilizarea perilor albi …o lasam pe altadat’
Momentan am sa incerc cu varianta BitComet-ului 1.02;ideea e ca intr-o luna si ceva imi schimb netul, in sensul ca acum am modem usb si pe viitor o sa fie wireless dar cred ca voi schimba providerul.
Cheers!
OK guys:))) I’ll follow the advice about hastening my white hair growth some other time…
Momentarily I’ll try BitComet 1.02. The thing is that in about a month I’ll change my internet connection, meaning that now I have an usb modem and in the future I’ll still have wireless internet but I think I’ll change my provider.
Vei scăpa de problema asta când vei trece pe fir, preferabil fibră optică de la RDS sau alt distribuitor în funcție de zona în care locuiești.
You’ll get rid of this problem when you’ll have a wired connection, preferably FIOS from RDS or any other provider depending on the area you live in.
Wireless connections aren’t intended to support file transfers at all, and the providers usually do everything that they can to discourage it. Their networks were created to support voice traffic, which has a completely different profile than normal internet use.
A telephone call is usually quite quick, then it’s over. A particular cell tower can support a lot of these.
A file transfer is usually lengthy, and a particular tower can’t support very many of these before its bandwidth is consumed. The economics of the business discourage internet usage other than quick email or browsing sessions. You should always keep this in mind when dealing with general wireless service, particularly when cities and towns want to tax you to implement it. It’s going to have this limitation, almost certainly, and most people won’t understand that in time to make sure it isn’t done that way.
If you get a vote, vote “no” to this sort of service and try to make sure your neighbors vote “no”, too. Don’t waste your tax money on half an internet.
Conexiunile wireless nu sunt concepute să suporte transferul de fișiere, și distribuitorii de obicei fac tot posibilul să-l descurajeze. Rețelele lor au fost concepute să suporte traficul de voce, care are un profil diferit de utilizarea normală a internetului.
Un apel telefonic este chiar scurt, apoi se termină. Un turn celular poate suporta multe apeluri. Un transfer de fișiere este de obicei lung, iar un turn celular nu poate suporta multe de genul ăsta până se consumă toată lungimea sa de bandă. Economia afacerilor de acest gen descurajează utilizarea internetului pentru orice altceva decât sesiuni scurte de email sau de navigare web. Trebuie să ții minte acest lucru când lucrezi cu un serviciu wireless, în special când orașele mari și mici vor să-ți ceară taxe pentru implementarea acestuia. Va avea această limită, aproape sigur, iar oamenii nu vor înțelege asta în timp pentru a se asigura că nu este făcut așa.
Dacă ți se oferă șansa să votezi pentru așa ceva, votează „nu” și încearcă să-ți convingi și vecinii să facă la fel. Nu irosiți banii contribuabililor pentru jumătate de internet.
Oh, don’t worry, tax payer money are not wasted *that way *here. It’s spent wisely on the mayor’s (or any other politician who respects himself) villa(s), limousine(s), vacations, some of those things need maintenance , gas.. etc. so it’s for very important things for the community. And when we vote, we vote for the one who manages to convince us that s/he’ll steal the least.
A, nu-ți face griji, banii contribuabililor nu sunt irosiți în acel fel aici. Sunt cheltuiți cu mare chibzuință pe ale primarului (sau oricare alt politician care se respectă) vile, limuzine, vacanțe, multe din aceste lucruri au nevoie de mentenanță, benzină.. etc. deci pe lucruri importante pentru comunitate. Iar când votăm, votăm pentru cel/a care ne convinge că va fura cel mai puțin.
You forgot “mistresses”.
Ai uitat “amantele”.
Hehehehehehe,
Nu ma gandeam ca a mea cerere de ajutor va crea un subiect complex,elaborat si bine pus la punct despre…politica …
Eu raman cu incapatanare pe subiect si ca sa clarific ceva: nu am cum sa iau de la rds intrucat nu stau in Ro..sunt in Uk acum asa ca astept propuneri de provideri buni de folosit la transferul de date .
Seara buna! :smiley:
I didn’t think my support request would create a well made, elaborated and complex subject about… politics …
I’ll stubbornly stay on topic to clarify something: I can’t get RDS because I don’t live in Romania, I’m in UK now, so I expect proposals about what ISPs are good for data transfers.
Have a good evening!
I did say limmos…
Aici ai nevoie de opinia unui localnic, preferabil vecin cu tine. Un distribuitor poate să aibă servicii bune într-o zonă și proaste în alte zone. Din câte văd căutând pe Google PlusNet este cel mai popular în materia internetului prin fir în UK.
You’ll need a local’s opinion on this, preferably one of your neighbors. An ISP can provide good services in one area and bad services in other areas. From what I see by searching on Google, PlusNET is the most popular when it comes to wired services in the UK.
