Listen Port Detection Failed
BitComet 1.37
Charter Internet
Netgear modem and WNDR3400v2, port is forwarded (I believe)
Windows 7, Norton
For every torrent I download I get this error even without firewall:
[statistics]
TCP Connections: Established: 0 [Max Unlimited] / Half-Open: 0 [Max 200]
Listen port of TCP: 21438 (Detect Failed)
Listen port of UDP: 21348 (Detect Failed)
Windows Firewall: Added [TCP added, UDP added]
UPnP NAT Port Mapping: Disabled
[Files]
LT Seeds: No support
ED2K link: Global Disabled
[Trackers]
Tracker connection error: 10013 An attempt was made to access a socket in a way forbidden by its access permissions
same here. but udp port are ok (open) just tcp port detect fail.
If your port is open there is nothing to worry about
