Listen port
Can you suggest a Listen Port to use because choose random port lists all low numbers.
Also if i change the listen port do i have to redo Port forwarding ?
select a port in the 50,000 to 60,000 range.
Yes, you must then forward that port in your router.
I also recommend setting a static IP address in windows.
Do i just make up a number in that range ?
Also how do i set up a static ip address.
My modem is not always on so dont i get a different address everytime i go on line?
Yes you can pick any single number in that range.
If you only have a modem then you dont need to do the static ip.
If you do not have a router, then neither port-forwarding nor the need for a static IP applies to you.
