Hi i have had this problem before and have been able solve it, but this time no matter what i do it won,t unblock. I am running windows 7, any advice would be welcome.
Thank you in advance ,
Fran
Fran
Without more information we won’t be able to help you.
Just go through the WIKI FAQ, there is a topic about the “yellow light” there.
franjipan2 @ this aint about your firewall or antivirus this is about your router if you used wifi to access internet. log in to your router as admin make some adjustment in it. check outgoing & incoming port used by the router. set your bitcomet with the same port. some of the router intergrate correctly with bitcomet but some is not. got to do some adjust & config to make it unblock. either it is blocked but you still can download smoothly…with a great speed for some router. try that out, hope it will solve your problem :rolleyes:
That would be helpful advice IF we were supposing that the original poster was, in fact, using a router and not a modem… but the point of the matter is that he offered absolutely no information about his setup at all.
@ cassie
agreed with you…but i just guest…might be…
We don’t like to “guess” that someone might be using a router, then spend an hour preparing instructions to fix a problem that doesn’t exist simply because the member didn’t spend a few seconds telling us what they actually do have.
We’ve been doing this a long time and have taken the time to provide a list of everything we need to know. If someone can’t be bothered to read it, then they must not want help very badly.
ahah…a strong statement…
