Local Remote Connections
Old Newbie,
:angry: I have read all the F.A.Q.and tried to remedy my problem,
no luck.Local connections only.
I am running 0.70 version,
Macaffee security centre,firewall etc.
My Modem is SmartAX-MT822 with Talktalk.
If anyone can “Please Help”
are you using a router?
The first thing I would do is check your listening port at canyouseeme.org
If you get any result other then open, then your being blocked by your router, firewall, or something else.
i get the same only remote ones if any (dht) do how can i fix it i have gone on the website to check the port and this is wt i get.
I could not see your service on ##.##.###.## on port (17704)
Reason: Connection timed out
y ohh y
:smiley: Checked out canyouseeme.org. It didn"t,so to try and resolve the problem i stuck my old
Speedtouch modem back in,everything okay now.
I"m thinking that my new modem must have a Router incorperated into it.if this is possible ?
Now going to read up on port fordwarding,IP Address etc. etc.Thanks for the help.i will let you know how i get on.
Jimmy,
If your modem has more then one plug to connect a computer, then it is a router also.
If it has wireless (wifi), then it is a router.
Venus,
Make a new topic and fully describe your problem and what hardware you are using, and firewalls.
