Logged in
Hey all.
Using the updated bitcomet .77 and have registered.
Since registering and logging in my “score” at the bottom-left has been slowly increasing.
Just curious really as to what this is about and why the score is important?
Any feedback with a point in the right direction would be appreciated!
Many thanks!
Dauntless
It isn’t, these are unimplemented features, and you should downgrade.
Kluelos - If you are on the Bitcomet Technical staff - Your reply is unusual. Downgrade? Why did they just push out version .79 then? Shall we start calling you MicroSoft? I simpler and kinder reply would have been in order. I too have asked the question - Why is there a score listed in the lower left side? No one has bothered to answer me.
Duantlessuk - If you do get an actual answer to this, please let me know!
BTW - I have posted way more than 2! it should read around 200!
Imaozi2000
Imaozi2000:
Our developers are hard at work, trying to improve all of the bugs in previous versions, with newer versions (thus the reason for having 0.79).
Kluelos’ advice to downgrade is simply because, although the newer versions (post-v.70) work well for some users, many others are still having issues with them. The logical thing to do, therefore, would be to suggest that Dauntlessuk downgrade to the last STABLE version (0.70), in oder to avoid problems.
As for the ‘score’ question, please read here:
http://forums.bitcomet.com/index.php?showt…17&hl=score
cassie :slight_smile:
