hi, why my bitcomet stop after download 10 m and how to login in (bottom of the bitcomet window)
thank’s before…
thank’s before…
Perhaps you should tell us what version of bit comet you are using???
otherwise you are just waisting your time, and ours in replying to you.
ps. so info about your internet connection would be useful too.
i have the same problem too i am using 0.73
Well you should be using v0.7, which can be d/led from here: http://download.bitcomet.com/achive/BitComet_0.70_setup.exe. I say you “should” use that version because I use it and have no such problems.
