Long Term Task Seeding
I always put the task seeding which I found that there are 3 ways to do this, since I do not know what is the different between those 3.
My question is which one more effective ?
1.  Leave each task active (orange arrow up).
2. Tick the enable long-term seeding in the option menu.
3. Tick the bypass task seeding rules (task always active in Advanced tab) in individual task.
Do I need to do all of the above to maintain Long Term Seeding ?
PF
In addition
I do not tick the task seeding rules (auto stop task when satisfying all the following conditions) in option/task/bitorrent menu.
Quite confusing.
PF
Long-term seeding is independent of bittorrent seeding.
Long-term seeding will work when #2 and #3 are both enabled, while #1 is not necessary.
