LOST BITCOMET
HELP I LOST MY BITCOMET WHILE UPGRADING FROM WINDOWS VISTA TO WINDOWS 7 I NEED TO GET MY DOWNLOADS BACK CAN ANYONE HELP? I ONLY HAVE ONE BACKUP FOLDER BUT IT DOESN’T GIVE ME AN OPTION TO UPLOAD OR RESTORE UNFORTUNATELY I DON’T REMEMBER WHAT VERSION I HAD. I HAVE A DELL INSPIRION 1545 LAPTOP WITH A ROUTER. THANKS
just go to bit comet homepage and redownload latest version and instal…pretty sure your downloads will appear when you login
I downloaded it and installed it. None of my downloads appeared. I’m don’t think I ever had a user name or signed in before. I just got my comet id today to get on this forum. Any other ideas? Thanks again
for all the time it takes you might as well redownload your torrents
To properly help you, we’d need more info. Start with the “READ THIS before posting”, and when you provide all the required info, let us know if you installed your new version overtop your existing windows, or in a separate partition, as well as your previous and current windows versions.
A screenshot of the backup folder mentioned above would be nice.
