- What version of BitComet are you using?
BitComet 1.25
- What type of Internet connection do you have (ADSL, etc.)?
ADSL2+
- Do you have a modem? Do you use a router? What make and model are each one of them? Have you forwarded your port?
I use a Dynalink - RTA1025W. I have forwarded my ports.
- If you have more than one router, be sure to mention the make and model of both devices, how are they connected (i.e. in which connector of both devices is the network cable plugged) and which one of the devices is connected to or is the modem.
Also, if you have more than one computer make sure to mention in this case, to which router is every one of them connected.
My router connects three computers
- What version of Windows, Firewall and Antivirus do you use?
I use Windows XP. I have Norton Antivirus 2007
- If you are asking about a specific torrent or file that you have downloaded, make sure that you include the complete torrent name, as well as the complete names of the files and their respective extensions/formats (e.g.: .rar, .wma, .bin, .cue, etc.).
I am downloading this torrent: XXXXXXX .
**7) For speed-related issues, please run various speed tests at a site such as speedtest.net (make sure that no other computer is using your Internet connection and that all other programs - including BitComet - are closed, during the tests). Include the results, along with the settings that you are presently using, in your post, so that we may review and offer suggestions to improve its performance. **
The first time I started downloading this torrent, it was downloading at 1.2 - 2mb/s a second, the next time I start it up, it goes right down to only 20 - 80 kb/s. When it was downloading at mb/s, I checked the “Peer” tab and I had alot of LT Seeders. Now, I only have 1. Why did the amount of LT seeders go down to only 1, and how do I fix it? :mellow:
