If you don’t like LTseed, then disable it, it’s clear you don’t understand it.
ive seen my torrent client make my browser not work by using ALL available bandwidth.
finding the proper settings will fix that. We would even have been glad to help you if you made a topic and asked, instead of jumping in the middle of another persons support request. Forums have rules and your using a free product and getting free support from volunteers, we aren’t obligated to put up with childish behavior or rants from users who have an exaggerated sense of entitlement. If you don’t like bitcomet, I’ll personally refund your purchase price.
long term seed is supposidly helpful, and people will seed, but downloads are slowed down when LTS is on.
This is an example of what you don’t understand. The purpose of LTseed is to speed up downloads, and it does just that. We’ve documented it increasing speeds greater then 10x the speed of a torrent on tasks with few bittorrent peers and many ltseed peers.
upload is maxed out. ive showed you screen shots.
Using proper settings works wonders, you should listen more and speak less (just my opinion)
im giving feedback because for years LTS has made my life difficult.
You can disable it by clicking one little checkbox, or you can limit how much bandwidth it uses. I even recommend users with very slow upload either limit or disable it, which I would have told you if you had read that annoying topic that’s linked throughout the forum titles “READ THIS before posting”, and made your own topic, but instead you jumped into the middle of another members topic. Not polite.
m going to uninstall my bitcomet now.
Best news I’ve heard all day. Take your attitude over to another forum, see if they put up with it.
